PI 3.1 not pooling NetFlow in Data Source
Thomas Kosowski
Good Morning,
I'm sort of a new when it comes to Prime, worked a lot with SolarWinds for the last 4 years. I have configured NetFlow on my 6509 and we are getting good statistics on the switch:
Flow Exporter HQprime:
  Packet send statistics (last cleared 00:22:09 ago):
    Successfully sent:         5377                  (6399043 bytes)
  Client send statistics:
    Client: Option options interface-table
      Records added:           463
        - sent:                463
      Bytes added:             46300
        - sent:                46300
    Client: Option options exporter-statistics
      Records added:           2
        - sent:                2
      Bytes added:             56
        - sent:                56
    Client: Flow Monitor HQcapturetraffic
      Records added:           129054
        - sent:                129049
      Bytes added:             6065538
        - sent:                6065303
Unfortunately nothing is being displayed in Prime under that device. We have no problems pooling configs and information from that switch using SNMP and that device is always reachable. I have configured proper destination IP and I have put source as the VLAN IP which is configured in prime. There is no ACL that would block this traffic from reaching prime. I haven't configure much in Prime because someone told me that as soon as Switch will start sending NetFlow information I will be able to see that under SERVICES/APPLICATION & VISIBILITY/DATA SOURCE.
I have read API 3.1 user manual but there is not that much info.
What I'm I doing wrong and what else I forgot to configure on Prime.
Any help is appreciated. Thx
Did you purchase a license for Netflow feature?
http://bit.ly/2qIEIJH
Yes. We have 2000 Assurance license.
