PI 3.10 Unable to update with fix PI_3_10_1-1.0.25.ubf
lov
In PI3.10 I am trying to install fix PI_3_10_1-1.0.25.ubf.
However this message appears "UBF with new version of update 'pi310_mrx' misses version '0.8.23' that was previously uploaded" and install fails.
Has anyone experienced this?
I am running build 3.10.0.0.205
marce1000
 - Looks like possible dependency on other patch , contact TAC for this.
 M.
5 Replies 5
marce1000
 M.
ElXandel
same error here
3.10.1 fix 1.0.23 is installed
feedback from TAC was
So as an update now please check the following regarding the issue in hand:
  • The image you’re trying to install is the same image you have installed as part of the 3.10 MR 1 build 23. This is the reason for the system not letting you install this image on top of it.
  • This MR 1 image had been republished due to an existing defect shown in the next link: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwc12966
  • This defect consists of a possible crash when trying to install the patch. There are no security or feature enhancements in the re-published release.
So, as an advice, you could avoid this upgrade as you already have installed the MR 1 update successfully through the previous release.
LukaszC
so having build 3.10.0.0.205 there is no way and not a need to install PI_3_10_1-1.0.25.ubf ?
According to TAC there should be no need to update
