PI 3.4 Compliance policy check subblock (policy-maps)
mario.jost
Level 3
Level 3
We have a hard time checking any blocks that have subblocks like routing (EIGRP named mode), policy-maps and crypto pki certificates. Let me show one example. We want to check following code:
policy-map QOS_OUT_CHILD
 class QOS_ROUTING
  set dscp cs6
  priority percent 5
 class class-default
  fair-queue
policy-map QOS_OUT
 class class-default
  shape average 2000000
   service-policy QOS_OUT_CHILD
 We have tried following rule set A:
Rule1:
Condition Scope: Configuration
Parse as Blocks: Yes (setting start expression only)
Condition match criteria: Matches the expression policy-map QOS_OUT_CHILD
Rule2:
Condition Scope: Previously Matched Blocks
Condition match criteria: Matches the expression class QOS_ROUTING
Rule3:
Parse as Blocks: No
Condition match criteria: Matches the expression set dscp cs6
Rule4:
Parse as Blocks: No
Condition match criteria: Matches the expression priority percent 5
Rule5:
Rule6:
Condition match criteria: Matches the expression class class-default
Rule7:
Parse as Blocks: No
Condition match criteria: Matches the expression fair-queue
With this ruleset, there is no violation even if we delete the fair-queue part in the configuration. It finishes with all green. We have done some two level block verification in our switch configuration (archive command) where we used following approach:
Rule1:
Parse as Blocks: No
Rule2:
Rule3:
Parse as Blocks: No
Rule4:
Parse as Blocks: No
Rule5:
Rule6:
Parse as Blocks: No
This works great, if the commands you want to check are unique in the configuration. The problem with policy-maps is, that we have multiple class-default classes, so prime builds multiple blocks and there is always a violation to be found because the fair-queue command is not present in the policy-map QOS_OUT. I couldnt find anything in the cisco prime documentary and the examples do not cover such a scenario. To check EIGRP in named mode, it is more complicated, as you have 4 levels down if you go into the af-interface mode. How do you get prime to check blocks within blocks to make sure the configuration is complete?
mario.jost
Level 3
Level 3
To answer my own question in case someone else comes accross the same problem some day. We couldnt find a solution for 3 or 4 level configuration blocks. Especially if there are keywords that are present multiple times in a configuration. We ended up using regex to check this configuration. So if you wanna check following code:
policy-map type inspect SELF2WAN
 class type inspect SELF2WANPASS
  pass
  inspect
 class class-default
  drop
policy-map type inspect WAN2SELF
 class type inspect WAN2SELFPASS
  pass
  inspect
 class class-default
  drop
We use following 2 rules to check this:
Condition Scope Details
Condition Scope: Device Command Outputs
Show Commands: show running-config | section policy-map type inspect SELF2WAN
Condition Match Criteria
Operator: Matches the expression
Value: (policy-map type inspect SELF2WAN)\n( class type inspect SELF2WANPASS)\n(  pass)\n( class type inspect SELF2WAN)\n(  inspect )\n( class class-default)\n(  drop)
Show Commands: show running-config | section policy-map type inspect WAN2SELF
Value: (policy-map type inspect WAN2SELF)\n( class type inspect WAN2SELFPASS)\n(  pass)\n( class type inspect WAN2SELF)\n(  inspect )\n( class class-default)\n(  drop)
So this regex only matches if these entries are found in the same order. This works great and is the best solution for us right now.
mario.jost
Level 3
Level 3
  pass
  inspect
 class class-default
  drop
  pass
  inspect
 class class-default
  drop
