PI fails after upgrade to 3.3 with error "Error generating key java.security.KeyStoreException: Could not create new key Could not generate RSA key for SSL"
esa_fresa
We upgraded PI from 3.2 to 3.3. After reboot it fails during "ncs start" with the following error.
The launchout.log files shows this:
Starting Health Monitor as a primary
Checking for Port 8082 availability... OK
FQDN for Certificate CN is: *** can't find cisco-prime: no answer
Generating RSA key
I *think* the below function is what is being run internally in PI when it fails.
Generate a public/private key pair and a self-signed certificate
I see the function takes the argument "-dname cn=myserver.mydomain.com" and according to launchout.log the Certificate CN is *** which doesn't match, so I think the function is throwing an error. We ran the command "ncs key listcacerts" which shows nothing.
Unfortunately I don't know enough about PI internals to know if i'm on the right path. Do I need to generate a new certificate, or am I lost on a wild goose chase here?
bart.t
Came across the exact same issue when upgrading PI 3.1 to 3.3
The command 'ncs key listcacerts' did not list anything as well.
I was able to fix this by generating a self-signed key manually before executing 'ncs start' again:
<hostname>/admin# ncs key listcacerts
<hostname>/admin#
<hostname>/admin# ncs key genkey -newdn
Enter the fully qualified domain name of the server: <fqdn>
Enter the name of your organizational unit: <any>
Enter the name of your organization: <any>
Enter the name of your city or locality: <any>
Enter the name of your state or province: <any>
Enter the two letter code for your country: <any>
Do you need Subject Alternative Names in the certificate (yes/no)?: no
Generating RSA key
<hostname>/admin#
As you can see command 'ncs key listcacerts' still doesn't list anything.
However PI was able to start this time and is now working like a charm.
8 Replies 8
Mark Elsen
 - What I notice is that this sentence does indeed not contain a FQDN but a singlet 'cisco-prime' ; is the network setup correct, DNS resolvers etc, and also is a domain specfied in the networking setup ?
M.
So I was wondering about that - do you know if PI works like IOS where a domain is required to generate the RSA key? Where PI is looking for the domain (ex. in a local host file, on DNS server, etc.)? How can we view the CN that PI is looking for in the certificate?
 - A domain is required (indeed)  and must be set in the running-config of Prime with the command
ip domain-name cisco-prime.your.domain (e.g.)
  As this action was part of the upgrade process ; you may well have to try the upgrade again, but correct this first (the above). It may be possible to correct this manually but I am in doubt (check the link below) :
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-2/admin/guide/bk_CiscoPrimeInfastructure_3_2_AdminGuide/bk_CiscoPrimeInfastructure_3_2_AdminGuide_chapter_011.html#task_1157368
M.
We do have the "ip domain-name xxx.xxx" command in the start-up configuration.
 - Check the DNS resolvers settings too and or where they functional and reachable during the upgrade ? If so , try the upgrade again and check wether this problem persists.
M.
bart.t
<hostname>/admin#
Generating RSA key
<hostname>/admin#
I have same problem with upgrading from 3.0 to 3.2
For my case problem is resolved with generating of self signet certificate of cisco prime before execute command NCS start
Thank you.
Thanks, it's working for me.
