PI info2
cisco.plus
Hello
Prime Infrastructure upgrade license we plan to purchase, my question was the PI hardware comes preloaded with Prime software or it needs to be downloaded and installed on the hardware appliance. Do we need to purchase VMware or it comes preloaded on the Prime hardware.
Are there different hardware for LMS and Prime v2.0
Hope to get some input
cheers
CP
AFROJ AHMAD
If you have ordered the Hardware Appliance ,it comes with the OS(linux). then you either need to run the cd\dvd for PI software which you have got along with the box.
if not then  you can download the .ISO image from cisco.com then burn it on the DVD and run the DVD.
other way to installed PI is to  installed VMware then you need to download the .OVA images from cisco.com and then deploy the ova to your VM.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/quickstart/guide/cpi_qsg.html#pgfId-63672
Yes there are different hardware specifications for LMS and PI 2.0:
for LMS:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/install/guide/install/prereq.html#pgfId-1155577
for PI :
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/quickstart/guide/cpi_qsg.html#pgfId-46865
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
