Pi monitoring 100% memory usage on WLC 5520
jfafinski
I'm monitoring many catalysts and 2 WLC 5520 witch Prime 3.0. I don't understand why Prime always monitor 100% RAM utilization for both WLC5520. That's wrong, "show process" indicates about 10% used memory...
Except the RAM utilization, both WLC are correctly monitored in Prime, I don't seem to have the same issue with my network devices.
If someone can help,
Thanks!
Jeremy
santimviejo
HI
Have you check monitor memory usage via SNMP?
Total RAM in machine: .1.3.6.1.4.1.2021.4.5.0
Total RAM used: .1.3.6.1.4.1.2021.4.6.0
Total RAM Free: .1.3.6.1.4.1.2021.4.11.0
If these OIDs are not on your device, you can see the device MIBs for the correct OIDs.
To get all information to create then reports or graphics you can send all this information to Pandora FMS monitoring tool.
https://pandorafms.com/monitoring-solutions/network-monitoring/
Best Regards
