12-11-2014 03:08 PM
We've got in trouble with a LMS to PI Migration maybe because the target devices are configured for Telnet
with a password only Login in place of the the common username Password Login Dialog in this Network.
LMS seams to can handle a Password only Login CLI Dialog with all of the devices but Prime Infrastructure claims "invalid cli credentials" for most devices but it seams to work with a lower part of the devices.
What can we do that PI can handle CLI login with Password only Dialog for all devices? Customer dont want to reconfiger the Network devices for username Password Login.
Steffen
Solved! Go to Solution.
12-12-2014 04:47 AM
looks like some database issue.
after deleting the device . Restart the services then add the device again ( try this for couple of devices)
Thanks-
12-11-2014 05:16 PM
Hi Steffen,
Only way it is possible is to Export (Operate > Device workcenter) the device , then Edit or correct\verify the credentials .
FYI: IN PI 2.2 , you will see default credentials set like we have in LMS that can be applied to any set of devices
Thanks-
Afroz
****Ratings Encourages Contributors ****
12-12-2014 03:08 AM
Hi Afroy,
Thx for your reply. Its not a question of wrong credentials. I tested exevry thing from ade+ commandline. I used a converted csv-export from LMS (where all devices was working). The problem is PI only related:
all devices in question are:
- SNMP reachable, because green check mark in device work center, but name and type is empty despite SNMP discovered infos and OID + name is written into the discovery=>reachable log if I try to discover this devices
- unmanaged, because claiming "wrong cli credential"
- ifm_inventory.log has some following dissent for all this devices:
postCollection() ... Cache status: false.
Error logging - Device <ip> Updated Successfully
delete and re-add this devices brings no improvement.
Steffen
12-12-2014 04:47 AM
Thanks-
