I'm seeing some strange behavior from some Catalyst 3560-E switches. I have a diagnostics tool that monitors SNMP OIDs for the switches, and it works by querying the switch for available OIDs under a given category, then stores the OIDs and periodically runs an SNMP get() on each OID to check its value. However, for some of the pimRPState OIDs, after some time the SNMP get() will return "no such instance" (both in the application and when querying the OIDs directly using net-snmp from a console). It seems that those rows are simply disappearing from the table.
My question is: is this expected behavior? Are entire rows in the pimRPState table supposed to disappear?
Thanks!
-Julian
