PIX 501 firewall does not accept keyboard input over serial connection.
mkvorosten
I am trying to connect to a PIX 501 firewall via serial connection. My problem is that I cannot issue commands to the firewall. Whenever I try to type something into the terminal, nothing happens. I have the connection settings configured properly (9600 baud, 8 data bits, 1 stop bit, no parity, no flow control) and have tried PuTTY and HyperTerminal and have the same results. I get output from the firewall, but my keystrokes do not seem to be going to it.
Thank you.
mkvorosten
Turns out we had a bad cable. Using a different one worked perfectly.
Thanks for letting us know.
Reminds me of some good maxims / rules of thumb / questions to remind oneself of and always ask:
1. 80% of issues are physical layer (YMMV). 80% of the ones remaining are human error.
2. Has it ever worked? If so, what's changed since then?
3. Can you recreate problem with a different device?
