PIX blasing snmp packets
jason.aarons
Level 5
Level 5
I see in the OpenView NNM Alarm Browser that PIX firewalls are hammering NNM with snmp traps about connections (show conn). This is overloading NNM. I propose the following change to stop trapping to NNM, but allow polling only;
BCBS-Pix515# show snmp
snmp-server host inside 10.10.254.233
snmp-server enable traps
BCBS-Pix515# config t
BCBS-Pix515(config)# snmp-server host inside 10.20.254.233 poll
!--- The host can query but is not to be sent traps.
Reference;
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a13.shtml
I'd still like to get traps, just not the connection entries, is there a better way?
sachinraja
Level 11
Level 11
how about enabling logging through the syslog service on the PIX ? this will give you all the logging messages and are sent to the particular server specified. you can use the following commands:
logging host inside 10.10.254.233 tcp/1468 (depends)
logging facility 3 (can be from 0 - 7)
logging trap 3 (0 - 7 level)
this will send traps to the server specified. the other command will poll the traffic.
you can refer to the command reference of the PIX 6.3, where you can find options for logging:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727a9.html#wp1028090
hope this helps.. all the best..
Raj
