Please help to configure this topology.
JAIRAM
Hi All,
I am jairam, I attended my first interview and one question been asked how to configure this given network diagram with how many possible way.
Please help me to complete this scenario and let me know what are the way mean where i can use hsrp or point to point ip addressing.
which devices is the question in regard to ? And what exactly is the question ? HSRP and point to point connectivity are two very different things.
Hi George,
Simple question was asked to me by interviewer here is the network diagram how you will configure it and what all are the way to configure.
Please educate me from start to till complete configuration.
balaji.bandi
As per your diagram (this is high leve) - number of combination can be done Layer 2 or layer 3
HSRP can be deployed on INTERNETSW1 and 2, CORE and 2
P2P ip address between FW and Core switches.
Internet sw1 and 2 can be Layer to bridge R1 and R2, So IP address can be used directly on FW1 and 2 outside.
BB
 Outer SW
config one VLAN that connect two edge router and two FW "FW HA".
Edge routers use the SVI of VLAN "from above step" and config HSRP under SVI.
in FW primary
route 0.0.0.0/0 toward the VIP of HSRP
Inside SW "Core"
config one VLAN that connect two Core SW and two FW "FW HA".
make the default gateway for use in Inside point to Inside interface of the Primary ASA.
