12-07-2010 08:39 AM
I would like to determine wich interfaces on the ethernet switch such as 29** is in trunk mode via SNMP. No matter active or not active.
Also I need to determine managed VLANs on the separate 3-layer switch, such as 3550, 4500, via SNMP. (i.e. show run | include interface VLAN)
What OIDs should I use?
12-09-2010 11:24 PM
For trunk ports try to use vlanTrunkPortTable( 1.3.6.1.4.1.9.9.46.1.6.1) - "The table containing information on the local system's VLAN
trunk ports."
12-10-2010 12:38 AM
Thanks a lot!
But these MIB return information about ACTIVE trunk ports only.
Could I recognize ALL trunk ports which was configured on the switch, but not active, shutdown or not linked right now?
