PoE Traps
zengxing
Is there any SNMP trap on PoE power loss or not enough power? Is it supported by LMS?
David Stanford
I don't think there's a specific trap for power loss or not enough power, but you can enable syslog traps. This will forward syslog messages as snmp traps:
snmp-server enable traps syslog
Make sure to also add the command
logging history warning
