port channel and etherchannel
daniel4579329
hi im in the middle of learning the ccna and i want to know
1. can different port channel be with the same number and if so, should i do it and what if i dont want to get comfused
can i put all my port channel that i have in the same number
2. same question about ether channel, can i do it and should i
thank for the help (:
dominiclugg
Port channels are bundled interfaces with a given number. Therefore each separate port channel require a different number. However multiple interfaces can be used with the same port channel number to bundle them together.
Port channel/Ether channels are the same. Some Cisco products name them port channels and others name them etherchannels.
thanks for the responde
but if Port channel and Ether channels are the same so why in the configuration there is "int port channel ID" (for portchannel) and  "channel-group ID mode on" (for etherchannel)
by the way do recommend to give the same ID to Port channel and to Ether channels
sorry if these question a bit stupid i just want to be sure what im doing
You can’t create ether channel with same ID’s on same switch and to the connected Switch.
It’s like your virtual interface where you are adding multiple physical interfaces.
