Port Security Traps Flooding NMS Servers
slcornish
All,
We have devices with port security set via command "set port security". The devices are expiring a maximum of 1 MAC address every minute and the action is to shutdown the port. An action of "shutdown" will trigger an SNMP trap to be sent to an SNMP trap receiver.
Is there a way to configure the device to not send the trap? We have all traps enabled except Authentication Failures and Syslog.
Please Advise.
Stephanie
17 Replies 17
Does the 6509 running cat6000-sup2k8.7-6-6.bin send trap 1.3.6.1.4.1.9.5.9 (sysConfigChangeTrap)?
You can verify that by examining the "show snmp notification mapping" output in enable mode on CatOS.
Trap Keyword Notification Object Name Notif. Sent Syslog
config sysConfigChangeTrap SYSCONFIGCHANGENOTIF
My 6509 doesn't have "notification" under "sh snmp".
Stephanie
