Port Utilization reports on LMS3.1
DHARSH_01
I am looking for a way to pull a report that will give me the port utilization % for each device. I have scrubed this application and to no avail. I am running LMS 3.1 on Windows. I have RME, DFM, IPM, Campus Manager all installed.
Can someone point me in the right direction?
Thank you
Joe Clarke
You will need to install the Health and Utilization Monitor add-on. By default, you will get a 90-day of HUM. You can then configure an Interface Utilization poller for your devices which will provide you what you want.
Thank you jclark
I have Unified Operations Manager as well. I found a report that says VG utilization. But when I run the report, it only tells me the status of the VG's, not the utilization. Is there a way to get report port utilization from the OM on the Voice Gateways?
You should start a new thread for the OM question. I know OM tracks utilization, but it will not maintain a history as HUM will do.
