Upgrading LMS 3.0 to 3.2 SQL issue
MathieuJM_2
i'm testing the upgrade of LMS 3.0 to LMS 3.2. All works fines except that error message:
Interactive SQL
Error database not found
Specified databse not found
I have the following options:
Continue / Stop / Exit
This append during the step: Upgrading ANI data.
Is this a know issue, could i simply click Continue ? The installation is pending for the time being.
Cheers
Joe Clarke
This is bad. This means there was a problem starting the ANI database for the upgrade. This could point to a corrupted ANI database or transaction log.
If you have a good backup of your LMS 3.0 data, I would highly recommend you contact TAC, and get the clean_system.exe tool (if you don't already have it). Run this tool to remove all of LMS from this server. Then, install 3.2 from scratch, and restore your previous backup.
