Hello all,
I am looking to replace the chassis of an ISR 4300 router.
I know of course that ISR routers do not have an external flash - the flash card is a daughterboard card inside the chassis.
When the new chassis arrives, will it be possible for me to open the lid of the old chassis, get the flash card, and then use it on the new chassis? I will be opening it up anyway to get the RAM, so getting the flash as well would actually be pretty convenient for me.
Can you someone confirm if this is doable?
Here is a related youtube video I found, where it shows how easy it is to unscrew the flash card from inside the chassis on an ISR router (fast forward to about 15.00 for the flash card removal): https://www.youtube.com/watch?v=CwfFQxd2zig
Thank you
