Power supplies for a 7200 series router
getwithrob
Level 3
Level 3
Is there a command I can issue to see the power supplies in a 7206 router?
getwithrob
Level 3
Level 3
'Looks like show env all will work....
David Stanford
how about show env all
ex)
router>sh env all
Power Supplies:
Power Supply 1 is QCS DC Power Supply. Unit is off.
Power Supply 2 is Zytek AC Power Supply. Unit is on.
Temperature readings:
chassis inlet measured at 16C/60F
chassis outlet 1 measured at 20C/68F
chassis outlet 2 measured at 26C/78F
chassis outlet 3 measured at 34C/93F
Voltage readings:
+3.45 V measured at +3.49 V
+5.15 V measured at +5.21 V
+12.15 V measured at +12.29 V
-11.95 V measured at -11.85 V
Thnks for the input. Is this the only way? We have several hundres 7206 and 7505&7 series devices. Surely there has got to be away to report on the power supplies. How about a show diag where the information is emailed to Cisco and a response is received showing information like card details?
Just a note: I ran the detailed device report and NOTHING shows for the Power Supplies on these 7000 series devices.
