PowersUpply
Michael Borbon
Hi Team,
I have a question. Is the EOS/EOL switch power supply is compatible with the latest migration switch?
Ex: 2960 PSU will be compatible to 9200 PSU.
Thanks!
Mike
2 Accepted Solutions
Mark Elsen
      - Not compatible ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
DanielP211
The power supply between C9200 and C2960 are not compatible -
C9200 - PWR-C5-XXX
C2960 - PWR-C2-XXX
BR
****Kindly rate all useful posts*****
Mark Elsen
      - Not compatible ,
 M.
DanielP211
C9200 - PWR-C5-XXX
C2960 - PWR-C2-XXX
BR
Ruben Cocheno
@Michael Borbon
As per datasheets,  it's not a supported 😞
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
