Practice question for ACL list
Michael1975
Visitor
This is a practice question. I know the answer of A is wrong,
But I do not see a difference between answers B - D.
Does anyone see the difference.
But, I just don't understand why the only one ACL is applied. A in and a out.  <<- this by cisco one ACL IN/OUT and you can add multi line for this only ACL
In this questions, the INBOUD does not even come into play. It has nothing to do with this question. <<- it Q not mention IN ACL not meaning you can not config it, you can config it but as I mention the goal of this Q is two point I mention above
MHM
6 Replies 6
Answer is B
since there is only one ACL IN and only ACL OUT
and the last ACL override all other ACL this ACL is 10 so only traffic deny is 10.0.0.0/24
Michael1975
Visitor
Wow. But, I don't get it.
All the answers all say OUT, so where is IN coming into play.
Plus, why so many permit AMY, the first permit ANY would catch all traffic, this meeting that rule, and the ACL will not process the request anymore.
I would think this has the exact same results. --- I am wrong, it's the way I am looking at it.
deny 10.0.0.0 0.0.0.255  - If this condition is met,
than anything after that would be permit would meet the condition of all other traffic.
1-this standard ACL so it filter source, the direction OUT meaning any traffic outbound from interface and it source 10.0.0.0/24 will deny
2- if the traffic 10.0.0.0/24 deny by first line the ACL will not check other line (permit ANY)
this Q make you learn two point
1- how many ACL apply to interface IN and OUT (which is ON in each direction)
2- if I apply multi ACL which one will work, the last ACL config under interface
MHM
Michael1975
Visitor
So, I was right only the first 2 lines will be processed. The rest of the ACL is pointless.
I assumed this was a valid ACL that could be used, but I guess because it is a test question they tried to confuse a inexperienced person by posting a ACL that was not written properly. well it worked.
What prompted them to bring up INBOUND? You and someone else brought up INBOUND, and nothing in this questions talks about having more than one INBOUND or OUTBOUND, if fact INBOUND is not mentioned in the question
MHM
Possibly, you're overlooking a crucial difference, the difference between numbered ACLs and named ACLs.  The former uses the same number to define the ACL, the latter often uses numbers for ACEs, but the ACL is represented by a name.
In your posted example, four different numbered ACLs have been defined.
As already mentioned in other replies, the four interface ACL assignment statements, defining what that particular ACL should be used as, is done four times, and for usage, each assignment would replace any earlier assignment, so, only the last is the effective interface ACL.
The forgoing is much like:
interface x
ip address 192.168.10.1 255.255.255.0
ip address 192.168.20.1 255.255.255.0
ip address 192.168.30.1 255.255.255.0
ip address 192.168.40.1 255.255.255.0
What would be the interface's IP?
BTW, initially @MHM Cisco World mentioned there can only be one IN and OUT ACL.  Well, that might be true, currently, but I recall(???), once upon a time, you could have other than IP protocol ACLs, concurrently, on an interface.  Vaguely also recall the number 6, but if correct, don't recall was that up to 6 INs and/or OUTs or 3 INs and/or OUTs.
The various number ranges, would identify the different protocols;
Table 1 - ACL Number Ranges
Protocol
Range
Standard IP
1–99 and 1300–1999
Extended IP
100–199 and 2000–2699
Ethernet type code
200–299
Ethernet address
700–799
Transparent bridging (protocol type)
200–299
Transparent bridging (vendor code)
700–799
Extended transparent bridging
1100–1199
DECnet and extended DECnet
300–399
Xerox Network Systems (XNS)
400–499
Extended XNS
500–599
AppleTalk
600–699
Source-route bridging (protocol type)
200–299
Source-route bridging (vendor code)
700–799
Internetwork Packet Exchange (IPX)
800–899
Extended IPX
900–999
IPX Service Advertising Protocol (SAP)
1000–1099
Standard Virtual Integrated Network Service (VINES)
1–100
Extended VINES
101–200
Simple VINES
201–300
