Prevent Ping Sweep & Broadcast
sherif1
Hello e1,,
I have a group of routers (7 in a row) placed in a tandem deployment with their two end routers communicating to a central point & with each router connected to some local subnets of the same major private network"10.0.0.0".
I need to achieve three goals:
1- I need to prevent someone in the central point from being able to send a broadcast ping sweep to every subnet on network "10.0.0.0" along the line of routers.
2- prevent pinging the directed broadcast address: An IP address that has all binary "1s" in the host bit portion of the address. Used to send data to all devices on the network. For example, 10.10.10.255/24.
3- prevent pinging the network address: An IP address that has all binary "0s" in the host bit portion of the address. For example, 10.10.10.0/24.
 Think about where the ping comes. Then, which device is the first one to receive the ping and put an ACL deny ping.
You can play with mask on the Access List but I´d go for blocking ICMP and done.
