Prime 2.2 - wired device availability
mbailey08
Visitor
We have recently setup a couple of reports to show wired device availability. The first month has been fine with top devices showing 100%, however since then we are getting  2267.67 or higher, ones on 10000%
If i change from Previous calendar month to specific dates or the last two weeks the figure just goes up.
We are running 2.2 with POODLE Fix 1.0.0, Maintenance release 1.0.0 and 2.2 Device Pack 2 2.0
Anyone else seen this?
Mat
Ashok Kumar
There's a know bug for this. Open a TAC case for it.
https://tools.cisco.com/bugsearch/bug/CSCus63826
- Ashok
Please rate the useful post or mark as correct answer as it will help others looking for similar information
Thanks Ashok - i will do.
Mat
