The following role settings allowed for users to view Config Groups and deploy (but not modify/create) in PI 2.X
Role Tasks/Permissions
Network Configuration
- Configuration Templates Read Access
- Configure Config Groups
- Deploy Configuring Access
With the above settings, PI 3.1.1 gives the error below when a user tries to access the Config Groups page:
You do not have access to the page 'Configuration Groups'.
If I add the following task/permission to the role, the user can view Config Groups but has Read/Write access
- Design Configuration Template Access
The above was tested with:
Version : 3.1.0
Build : 3.1.0.0.132
Critical Fixes:
PI 3.1.1 ( 1.0.0 )
Device Support:
Prime Infrastructure 3.1 Device Pack 1 ( 1.0 )
