Prime compliance audit
Thomas Schmitt
i need some help by creation of a compliance audit job on PI 3.0. Probably i misunderstand some point, can you please take a look?
To be clear, this is just an example, so i don't need a workaround for this case, rather I'm going to configure a lot of checks in simular way.
In this example, I would like to check this configuration block:
aaa group server tacacs+ TACACS-SERVER
 server name TACACS-SERVER-1
 server name TACACS-SERVER-2
 ip tacacs source-interface Vlan999
So I created a new policy and added "aaa" rule for IOS.
Condition 1 should select the "aaa group server tacacs" block:
RegEx test is fine:
Condition 2 should count tacacs servers in the tacacs group:
 RegEx test is also fine:
So I got this 2 conditions:
Condition 1 should select "aaa group server tacacs" block or Raise a Violation and stop.
Condition 2 is checked only, if 1 could select the block. Here i check, if there are exactly 2 servers, otherwise Raise a Violation
But it dosn't work like this! I did some tests with this rule (on saved configuration, all other rules are disabled) and the audit job succeeded every time, with any configuration. For example was for a device with this legacy TACACS configuration no violation raised, there wasn't aaa server group at all!
tacacs-server host 10.1.1.1
tacacs-server host 10.1.1.2
tacacs-server directed-request
Can someone please help me to understand the problem? What do I do wrong?
Mark Malone
Hey
Just an option this is the way I do it and it works , avoid reg expressions just use the command syntax match against the string instead its easier and you can raise violations alarms against it , then you can run a config change against all those devices to remove old config
Hi Thomas,
I tested around with block parsing and figured out the situation is as following:
The block means that the configuration can only fail when a block exists.
In your example when you define a block start as following:
(aaa group server tacacs)
and your device is instead configured as:
Prime can not find the block and succeeds.
Best regards,
Steffen
mifi
Hi Thomas,
I struggled with the same issue and finally I found that you problem is the "Block Start Expression". I had the same working for the RADIUS definition, but the TACACS definition includes the plus which has to be escaped, since the expression is evaluated as RegEx. When you enter "aaa group server tacacs\+ .*" as block start it will work.
Michal
