PRIME GUI not working
S.ashok S
Installed Prime 2.2 version, able to login using ssh but unable to login into GUI. Below is the ncs status output.
PRIME/admin# ncs status
Health Monitor Server is running.
Matlab Server Instance 1 is running
Ftp Server is Disabled
Database server is running
Matlab Server is running
Tftp Server is Disabled
NMS Server is running.
Plug and Play Gateway is disabled
log4j:WARN No appenders could be found for logger (com.cisco.ciscossl.provider.ciscojce.CiscoJCEProvider).
log4j:WARN Please initialize the log4j system properly.
SAM Daemon is running ...
DA Daemon is running ...
Request some one help to resolve the issue.
Thanks in advance
Ashok Kumar S
ngoldwat
Level 4
Level 4
It does not look like the services came up cleanly.  Try a ncs stop. Then (with root access) ps -e | grep 'CSCO|java' -- if there are stale processes then kill -9 <PID>. Then perform a ncs start.
I have the same issue but in my case the prime is installed as FIPS and can't run the root commands.
