Prime Infr2.0 does not display vlan & ip interface info for Nexus gear
SpongeRob
Recently installed PI2.0.  Following collection and archive only the IOS devices show vlan and IP interfaces from the device work center.  The Nexus 7k & 5k gear do not.  Is this expected behavior for Nexus OS in Prime or is something mis-configured ?
Thanks in advance for your suggestions !
2 Accepted Solutions
AFROJ AHMAD
Hi ,
I have checked and confirmed that Unfortunately  this feature is not supported  for NEXUS . I mean the VLAN and Interface information.
and I think "port-channels" are also not supported.
But this is in the road map ,soon we will have this feature supported as per my knowledge.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
"Cisco Prime Data Center Network Manager"  ideally yes...  but I am not an expert on that
Thanks-
Afroz
AFROJ AHMAD
Hi ,
Thanks-
Afroz
Holy Moley - I suspect then the Prime DCNM arm does, do you know ?
Thanks-
Afroz
Thanks Afroz - do appreciate your thoughts !
How does one rate these - I see the start bar doesn't allow me to change it ?
