Prime Infrastructure 1.2 Appliance fails to start NCS
Ji-Won Park
Hello all,
I've only experienced with PI virtual appliance and today i've received a brand new physical appliance to configure for a client. However, the device boots up normal but fails to start NCS which is not normal I believe.
Here’s the device information:
SPID: PRIME-NCS-APL-K9
VPID: V02
Serial: *
Here’s the log:
PRIME01990701/admin# ncs status
Health Monitor is running, with an error.
failed to start NCS on startup Health Monitor
Reporting Server is running
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is stopped.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
Status
PRIME01990701/admin# ncs start
Purging PurgeSAMPollerRecods
{Fri Sep 20 18:21:15 EST 2013} ===================================================
{Fri Sep 20 18:21:15 EST 2013} =========Issuing dbadmin -v start=================
{Fri Sep 20 18:21:16 EST 2013} =======executing delete sql script sam_poller_jobs_cleanup.sql====
{Fri Sep 20 18:21:17 EST 2013} ==========Issuing dbadmin -v stop=================
{Fri Sep 20 18:21:43 EST 2013} ===================================================
Completed purging SAMPoller Records
As first time is not present - removing .dbCreated
NCS processes - sam_daemon,da_daemon and syslog_daemon are already running; shut down before starting again, aborting...
Do I need to use a recovery disc to re-install? Please advise!
Thanks in advance.
J
Mahabir Prasad
Looks like you are hitting bug CSCuf25963.
Please follow below instructions:
1/ Please login into the PI server via ssh or on console
2/ Please type ncs stop to stop services
3/ Please type root_enable to setup a root password
4/ Please type root to jump into the shell
5/ Please type vi /opt/CSCOlumos/conf/messaging.properties to enter into the vi editor
6/ Please change an IP address to proper one
# JMS Broker URL
broker.url=ssl://xxx.xxx.xxx.xxx:61617?wireFormat.maxInactivityDuration=0 <- in this line
broker.name=XMP_Message_Broker
7/ Please save the file and exit from root shell
8/ Please type ncs start and wait till all services are up and running
That could fix your issue.
Mahavir
[Do rate helpful posts]
I got a response from CTAC. They say PI appliances are shipped with corrupted image and they recommend me to download ISO recovery image and recover the box.
I just realize that Cisco probably does not verify checksum before they put it on the appliance..
Anyways, thanks for your recommendation but i will just recover the appliance as per Cisco..
Thank you
J
Jiwon I'm facing same problem. Could you help kindly. My case the aappliance is stuck at init run level 3 and the ncs status command shows all services as stopped
