Prime Infrastructure 1.3 - Netflow Raw reports not generating (without a record n°).
oliv Parcell
I am currently testing Prime Infrastructure 1.3 especially for the Assurance feature. So I have downloaded the image and installed the tool with a Demo license.
I have configured some Catalyst4500 - IOS 03.02.00SG (15.0.2SG) to send some Flexible Netflow information to P.I.
When trying to generate some raw netflow records under Report > Report Launch Pad > Saved Report Templates > Report Details (with a defined number of records, for example 1000);  there is no problem I can see the statistics when running the report.
But when trying to generate the same report without a defined number (I should be able, because if we leave Blank we should see ALL records).
I have the following message => No data matches the specified criteria for the report.
Does someone using Raw Netflow reporting experiencing the same behaviour ?
Thanks in advance.
Best regards.
Oliv.
0 Replies 0
