Hi guys,
Do you know if PI 2.0 supports C1750-Series and C3550s? Before installing Device Update 4.0 they were on the "Device Level Support" list after installing DU4 they disappeared. I am not saying they worked, as they did not ("collection failure" or "partial collection failure"), also there was no minimum IOS mentioned for them, now just vaporized from list.
Have anybody succeeded adding to PI2 C2950? Same problem here. If so what IOS did you had installed on the switch? From Device Support List they should work fine from IOS 12.1.
Can anyone explain or point me to Cisco doc to explain: "collection failure" or "partial collection failure"?
Thanks for help.
