02-11-2014 04:52 AM
I´d like to know if evaluation version of Cisco Prime Infrastructure 2.0 (PRIME-NCS-VAPL) does not provide the feature "Planning Mode" to conduct a Predictive Site Survey.
Monitor>Site Maps>Select an Site>
At the drop down list (select a command), I can´t see planning mode. The options are: New Building, New Outdoor Area, Edit Campus/Site, Delete Campus/Site, Configure Interferer Notifications.
I also notice that "Add Access Points" does not appear.
see the att image.
Tks.
02-11-2014 05:54 AM
Hi ,
1. Monitor > Site Maps
2. Select the appropriate location link from the list that appears.
A color-coded map appears showing placement of all installed elements (access points, clients, tags) and their relative signal strength.
CLICK on the " color-coded map "
Now on the right hand side Drop Down Menu , you should be able to see the "Planning Mode"
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
02-11-2014 06:05 AM
If you see on the snapshot, I don´t have any access point associated to my floor plan.
But if I try to associated one of my 2 access points mapped by a controller, this does not appear. So, I'm not even getting the option to join one of my access points to the plant.
Tks.
