Prime Infrastructure 2.1. Image destribution problem.
DOM.RF NOC
Hello! I have a problem with distribution IOS on Cisco devices. PI version is 2.1.
I have the image on local repository. When i try to distribute it on any devise i receive the following error (space on the flash enough):
On Prime web interface - Jobs Dashboard:
SWIM5018: Copy operation Failed. Probable Causes : 1. Connection Time out. 2. Disk Space full. Recommended Action: 1.Please check the connectivity of the device. 2.Check if enough space is available for copy operation.Error loading image to Flash.For more details please check /opt/CSCOlumos/conf/ifm/swim/jobs/10.10.10.10_tftp_telnet.log for the output from the device on which the image transfer failed.Image Copy Operation Failed
On Prime log repository - /opt/CSCOlumos/conf/ifm/swim/jobs/10.10.10.10_tftp_telnet.log:
ade # vi 10.10.10.10_tftp_telnet.log
dir /all flash:
Directory of flash:/
    2  -rwx     6918153   Mar 1 1993 00:55:38 +00:00  c2970-lanbasek9-mz.122-44.SE.bin
    4  -rwx        4014   Mar 5 1993 23:45:28 +00:00  private-config.text
    5  -rwx        5324   Nov 8 2012 07:44:00 +00:00  vlan.dat
    6  -rwx        7560   Mar 1 1993 01:54:28 +00:00  23052014.cfg
    7  -rwx        5144   Mar 5 1993 23:45:28 +00:00  multiple-fs
    8  -rwx        3828   Mar 5 1993 23:45:28 +00:00  config.text
15998976 bytes total (9052160 bytes free)
HOSTNAME#copy tftp://10.5.5.5//c2970-lanbasek9-mz.122-44.SE6.bin flash:c2970-lanbasek9-mz.122-44.SE6.bin
Destination filename [c2970-lanbasek9-mz.122-44.SE6.bin]? c2970-lanbasek9-mz.122-44.SE6.bin
Accessing tftp://10.5.5.5//c2970-lanbasek9-mz.122-44.SE6.bin...
Loading c2970-lanbasek9-mz.122-44.SE6.bin from 10.5.5.5 (via Vlan110): !... [timed out]
%Error reading tftp://10.5.5.5/c2970-lanbasek9-mz.122-44.SE6.bin (Timed out)
HOSTNAME#disable 1
HOSTNAME>
HOSTNAME>
HOSTNAME>_tune_^H ^H^H ^H^H ^H^H ^H^H ^H^H ^H
HOSTNAME>
As i see, there is a TFTP timeout on session from Prime.
I've seen topics related to this, but I have not found an acceptable solution. Tell me, is there any way to solve this problem?
Thanks in advance
mcsadmin10
I am trying to update switch software with prime, and I am finding it to be quite cumbersome!
Any idea on this issue?
