Prime Infrastructure 2.2 No displaying client data using SNMP v3
richardpreece
When using Prime 2.2 with SNMP
Using SNMP version 2 we get the client data displayed under Device Details-Clients-Current associated Wired Clients as above.
However, nothing is displayed if we use SNMP v3 with full MiB access.
Any ideas as to why this doesn't work with SNMP v3?
Richard
Marvin Rhoads
I recall a couple of threads that reported similar issues. Please have a look at them (below) and see if either helps.
Root cause is snmp-server engineID duplicated:
https://supportforums.cisco.com/discussion/13122461/prime-infrastructure-31-snmpv3-issues
Root cause is SNMP contexts must be defined:
https://supportforums.cisco.com/discussion/11841726/endhost-unreachable#3960325
5 Replies 5
Marvin Rhoads
I suggest that you upgrade the PI code to the latest one as well.
Hi Pari,
we would but the h/w isn't compatible with the next version.
Hi Marvin,
It was the context I required. I just missed out the MiB viw required at the end initially. The following now works!
snmp-server group RO v3 auth context vlan-id read FULL-MIB-ACCESS
Many Thanks
Richard
Great - thanks for reporting the successful outcome and rating.
