HTTPS Connection on CNA 6.3.1 now fails
AlexcoKenoIT
Frequent Visitor
Frequent Visitor
I just upgraded to network assistant 6.3.1 (from 6.3) and now I can't access any of my https switches anymore, but all of my http connections still work. The release notes do mention a change:
    • TLS protocol has been enabled in CNA to connect the TLS supported device via HTTPS
Any ideas how to disable this?
Rad Slk
Visitor
HI
I have got the same problem.
After CNA upgrade to 6.3.1 I can not get https access to my 2960-TC-L L2 switches.
in the same time CNA 6.3 with https works OK.
Genarally:
http via CNA 6.3.1 or web browser is working OK.
https via CNA 6.3.1 not OK and via  web browser is OK
I have tried to upgrade IOS to version 15.0.2: c2960-lanbasek9-mz.150-2.SE10a (previously version 12: c2960-lanbasek9-mz.122-55.SE10) with no luck.
*I have also got one L2 switch 2960X-TC-L switch with IOS 15.0(sa)EX5 C960-UNIVERSALK9-M which is reachable via https in CNA 6.3.1
I do use CNA for performance/health and topology monitoring and for me it is quite good tool.
I will appreciate any help in this subject.
Rad
 - This issue has been reported in a few (separate) threads (already); clearly it must be reported to TAC (create a ticket@cisco)
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
