10-03-2016 10:34 AM
We have Cisco Prime Infrastructure 3.0 setup on our network as a NetFlow collector. Currently, the ASA5520 at the network edge is setup to export NetFlow information to CIsco PI 3.0. We're looking to use Prime as a network traffic analyzer to gauge internet bound traffic that goes across the ASA5520. Looking for some help on how to properly configure Prime for Network Traffic Analysis for our given scenario.
Thanks.
10-03-2016 03:05 PM
You will need to make sure that Prime Infrastructure runs an Assurance license type for NetFlow monitoring to be enabled.
Configure the ASA to export the desired NetFlow statistics to the UDP 9991 port in the Prime Infrastructure server.
Once the ASA shows up as a DataSource under Services > Datasources, setup the Endpoint Association to match it with a specific site.
The setup required is discussed in the link below:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/administrator/guide/PIAdminBook/metrics.html#59007
Luis
10-04-2016 11:07 AM
I'm specifically looking for information on how to customize and detail the NetFlow output in Prime Infrastructure.
10-10-2016 08:32 AM
Bump
