Prime Infrastructure 3.10 - simple cli changes
jhauff
Community Member
Many moons ago, Ciscoworks and Prime LMS had the ability to create a job by using just a cli option (no template) to run several CLI commands on an unmanaged device.
All it needed was to be able to connect with a switch, have a valid login (tacacs or local). Then it would run the cli commands as if I was logged into the switch myself.
Im trying to find that same ability in PI 3.10, but its alluding my efforts.
Does anyone have any ideas how this is done in todays version?
iportuga
There is no way to execute commands on an unmanaged device. The CLI template option achieves the expected outcome.
