Prime Infrastructure 3.8 Port Groups
Filip Po
Hello.
Prime Infrastructure supports four types of system-defined port groups. As and when new devices are added to the system, the ports of the devices are automatically assigned to the respective groups
  • Trunk Ports—Ports that are connected to a Cisco device or other network devices (Switch/Router/Firewall/Third party devices) and operating on “Trunk” mode in which they carry traffic for all VLANs.
  • Link Ports—Ports that are connected to another Cisco device or other network devices and are operating on “VLAN” mode and are assigned to a VLAN.
  • Access Ports—Ports that are connected to an end host, IP phone, servers, Access Points (AP) or video end points and operating on “Access” mode in which they carry traffic for only one particular VLAN.
  • Unconnected Ports—Ports are unconnected
But in reality, it doesn't work. Many access ports end in the Link Ports group. So the alarm arose on the down/up the flap of the port as critical. Access ports have turned off DTP, are in access mode, don't have CDP run, STP Port Fast is on.
Q: How can I force to change the Port Group from Link to Access by an automatic process of the PI?
I'm not looking for a workaround but a solution.
Thank you.
Regards, Filip
Thank you
0 Replies 0
