Prime Infrastructure and syslog
sdavids5670
Level 2
Level 2
In the "Cisco Prime Infrastructure 2.0 User Guide" it states:
Prime Infrastructure logs all emergency, alert, and critical messages generated by all devices that are
managed by Prime Infrastructure.
Prime Infrastructure also logs all SNMP messages and syslogs it receives. To view syslogs, choose
Operate > Alarms & Events, then click the Syslogs tab.
Syslog Pre-defined Filters
Prime Infrastructure uses the following syslog filters:
Severity 0 and 1
Severity 2
Environmental Monitor
Memory Allocation Failure
Catalyst Integrated Security Features
Cisco IOS Firewall Denial of Service
Can this be changed or is this Pre-defined filter something I have to live with?  If it can be changed, where?  The user guide doesn't get into it (at least not that I could find).
AFROJ AHMAD
Hi ,
Directly only sev 0,1 and 2 syslogs are supported in PI 2.x  so far.
but you can edit a properties file and get it working for other severity as well.
check the below link:
https://supportforums.cisco.com/discussion/11645481/prime-infrastructure-12-syslog
hope it will answer your query.
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
Thanks!
