Prime Infrastructure not using Proxy settings
Patricia Oliveira
Community Member
We've configured Prime Infrastructure proxy setting and even then we saw PI going to the firewall to access TAC support page:
Please, check below the proxy log:
Feb 12 18:32:05  JW801RJ1 RT_FLOW: RT_FLOW_SESSION_DENY: session denied 10.21.97.193/37121->72.163.4.70/443 junos-https 6(0) CLEANUP GREENZONE AMBERZONE-A
Feb 12 18:32:08  JW801RJ1 RT_FLOW: RT_FLOW_SESSION_DENY: session denied 10.21.97.193/37121->72.163.4.70/443 junos-https 6(0) CLEANUP GREENZONE AMBERZONE-A
Feb 12 18:32:14  JW801RJ1 RT_FLOW: RT_FLOW_SESSION_DENY: session denied 10.21.97.193/37121->72.163.4.70/443 junos-https 6(0) CLEANUP GREENZONE AMBERZONE-A
Has anyone pass through this issue also??
Vinod Arya
If you are using PI 2.0, it may be mostly :
CSCum47583    PI 2.0 is not able to connect to cisco.com to check for updates
-Thanks
Vinod
**Encourage Contributors. RATE them. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
-Thanks
Vinod
Vinod,
I'm running 2.0. Checking the bug report and the Patch download area, there ins't a fix (patch) for this issue, right?
Thanks for your help,
Patricia Oliveira
Unfortunately yes, there isn't a fix. Fix is planned for PI 2.0.1.
-Thanks
Vinod
Running 2.1 and got the same problem.
tks
