Prime Infrastructure Power Supply report
Dawit.Zeru
Hi All,
is there a report that can show me :
1. all the device S/N - i.e. PS/FAN/Chassis/Gibic?
2. can i custom a report to show a specific S/N  i.e. show me all interface that have a Cisco Gibic and its S/N? or report with device and PS S/N?
thanks
balaji.bandi
what is the version of PI (latest may have some additional reports changed like 3.10)Not fully you can generate reports are you looking to do with PI ?
instead, you can use out-of-the-box to get reports in excel using Python :
https://github.com/pavelstef/cisco_devices_info_collector
BB
Hi Balaji,
the CPI is in version 3.10,
what i need from the Prime is a full detail hardware report (i.e. all the components in the Switch / Router)
is it possible?
thanks
dawit
