Prime infrastructures over DMVPN
mecharek1
I want to know what are the best practices for deploying prime infrastructure 3.1 with DMVPN knowing that I manage all devices through loopback interface and I have a fiber and WiMAX links ( i use bfd static route).
Also, can I receive alarms if the LAN interface fails Via the syslogs
Shen I used the snmp server enable traps command a message appears " snmp mib nhrp is disable.
Thank you for your orientations.
0 Replies 0
