Prime Infrastructute 3.2
Hi all,
a customer must renew the maintenance contract of the virtual Prime infrastructure version 3.2.
it needs to load more than 25 license packs, but the current version does not allow this.
How can this problem be solved?
5 Replies 5
Leo Laohoo
Upgrade to a more recent version and enable Cisco Smart License.
Thanks @Leo Laohoo .
could you tell me the sku code to update version 3.2 to a more recent version?
The entire list of Prime Infrastructure can be found HERE.
HINT:  Look at the Release Dates.
IMPORTANT:  Do not forget to read the Release Notes.
I could not find the upgrade sku code to use on CCW
  - Check this document :
               https://www.cisco.com/c/dam/en/us/products/collateral/cloud-systems-management/prime-infrastructure/presentation-c97-735996.pdf
 M.
