Prime LMS 4.2.5 : Define baseline templates to identify public interfaces
drizvi
Prime LMS 4.2.5
I need to define baseline template(s) for the following:
* Identify Devices configured with Public IP address on any interface
* Check for presence of ACL on those interfaces (ACL name internet-acl for example)
* Generate a report of devices matching or violating above criteria.
Optional:
* Use the same or different template to deploy the correct configuration (ACL defined and applied to interface)
drizvi
opened a TAC case but no answer so far... bumping this so maybe someone can comment.
If you have news please share - we are in the same boat I guess.
