Prime LMS 4.2 NetConfig Job Output Question
Bin Shen
Version: Prime LMS 4.2.5
NetConfig Job: show ip nat translation
The above is one example NetConfig job we configured to run daily on one particular device. Is LMS able to send the job output details in a email rather than just a link to the job and summary of job status?
I found it's not quite convenient to log in to LMS every time to check the job output, especially when you are on the road.
Thanks.
AFROJ AHMAD
Hi ,
This is an expected behavior , you can only see the output of the Netshow command on the result job or login via link to the job status.
No email attachment option with Netshow :(
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
