Prime LMS: Syslog filter issue
alex.dersch
Level 4
Level 4
for a subset of my devices i do not receive syslog messages. I believe they get filtered out. I deleted all syslog filters and set the Message Filter Type to Keep and the Include interface of selected devices to Yes. Then I restared the system.
But I still see under Admin > Collection Settings > Syslog that there a messeages are filtered.
Any ideas?
regards
alex
24 Replies 24
Do:
no service sequence-numbers
Then see if the messages show up in the reports.
I did remove the service sequence-numbers but still the same. Counter of filtered messages rises but they don't show up in the report. I also figured out, my firewall syslog also don't appear. It's very odd, they even don't show up in the syslog_info.
Also my Wireless LAN Controller messages don't shop up. That really confusing, all the messages were available at my old LMS 4.0
I compared to syslog messages in SyslogCollector.log and it seems there is a problem. First is one which is processed correctly.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, FcssEmblemProcessor - About to process the syslog string  : Sep 27 08:49:09 nos-ch-wbn-sw01.nosergroup.lan 613189: NOS-CH-WBN-SW01: Sep 27 2011 10:49:09: %AUTHMGR-5-START: St
arting 'mab' for client (000c.2995.d268) on Interface Gi0/8 AuditSessionID 0A0080FD0000007E6917871E
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Parser :
com.cisco.nm.rmeng.fcss.common.FcssEmblemAFormatParser@7109c4
com.cisco.nm.rmeng.fcss.common.FcssEmblemBFormatParser@1385660
com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
com.cisco.nm.rmeng.fcss.common.CSSSyslogFormatParser@161dfb5
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, EmblemA not valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, EmblemB not valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, EmblemA valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Setting daemon date
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, After adjusting the offset Tue Sep 27 08:49:09 GMT 2011 GMT 27 Sep 2011 08:49:09 GMT
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Parsed using the parser :
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, FcssEmblemProcessor - Valid EMBLEM format. Passing on...
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, deviceList set from hostname
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Converted syslog to filter string. Filter string is 10.0.128.253;;;AUTHMGR-5-START: Starting 'mab' for client (000c.2995.d268) on Interface Gi0/8 AuditSessionID 0A0080FD0000007E
6917871E
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, ^((\S+);;;(\S+)(-(\S+))?-(.*)(-(.*\s*))?\s*:\s*.*)$
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Inside Pattern evaluation trueping this syslog
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, getInterestedSubscribers() - List of interested subscribers -
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, FcssAbstractObjectForwarder - Forwarder queue size is 15
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, FcssAbstractObjectForwarder - Forwarder batch size is 50
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, FcssFilterProcessor - Handed off syslog to forwarder. Destined to subscriber nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Entered zero size
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,639, got the command
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,639, FcssSubscriber - Posting new syslogs
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,641, FcssSubscriber - After write
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,685, FcssSubscriber - Posted syslogs, waiting for ack
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,685, FcssSubscriber - Response is true
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,685, FcssSyslogObjectsForwarder - incremented stats.
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,685, Entered zero size
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, FcssEmblemProcessor - About to process the syslog string  : Sep 27 09:37:22 fx-ch-hom-sw13.frox.com 149770: FX-CH-HOM-SW13: Sep 27 11:37:21: %CDP-4-DUPLEX_MISMATCH: duplex mi
smatch discovered on GigabitEthernet0/23 (not half duplex), with NOS-CH-HOM-AP01 FastEthernet0 (half duplex).
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parser :
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, EmblemA not valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, EmblemB not valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, EmblemA valid.
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Setting daemon date
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, After adjusting the offset Tue Sep 27 09:37:22 GMT 2011 GMT 27 Sep 2011 09:37:22 GMT
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parsed using the parser :
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, FcssEmblemProcessor - Valid EMBLEM format. Passing on...
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 09:37:23,501, getInterestedSubscribers() - Incrementing filtered count for nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 09:37:23,502, getInterestedSubscribers() - No interested subscribers. Returning null.
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 09:37:23,502, Entered zero size
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Parser : com.cisco.nm.rmeng.fcss.common.FcssEmblemAFormatParser@7109c4
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Parser : com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 08:49:09,804, Parsed using the parser : com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
6917871E
This is the one which doesn't shop up:
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parser : com.cisco.nm.rmeng.fcss.common.FcssEmblemAFormatParser@7109c4
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parser : com.cisco.nm.rmeng.fcss.common.FcssEmblemBFormatParser@1385660
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parser : com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parser : com.cisco.nm.rmeng.fcss.common.CSSSyslogFormatParser@161dfb5
SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parsed using the parser : com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
it seems somehow it doens't apply the filter so it does not know which subscriber it should use.
whereas on the good message
6917871E
SyslogCollector - [Thread: SyslogObjectForwarder] DEBUG, 27 Sep 2011 08:49:14,685, Entered zero size SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 08:49:09,804, deviceList set from hostname
6917871E
oops, that was to much.
it seems the message can not be processed at a good one. the good one.
6917871E
6917871E
the one cannot be processed:
SyslogCollector - [Thread: FilterThread-0] DEBUG, 27 Sep 2011 09:37:23,502, Entered zero size SyslogCollector - [Thread: EvaluatorThread-0] DEBUG, 27 Sep 2011 09:37:23,499, Parsed using the parser : com.cisco.nm.rmeng.fcss.common.FcssGenericFormatParser@1aed5f9
You did not post enough of the log file to see why this message is not working.  Can you post the new SyslogCollector.log now that you have removed the sequence numbers?  Also, post the output of the command "env" while logged in as root on the Solaris box.
Hello Joseph, i can't send you the log at the moment. Somehow i screwed my LMS. See threat
LMS Prime: After adding a new Certificate LMS Services not starting
As soon i solve this i will send you a fresh set of log files.
Alex
Hello Joe,
i set up a new LMS Server and i still have the same problem.
I attached the SyslogCollector.log all devices where the Hostname start with FX-CH-HOM-SW are not processed as they supposed to. And each time i get the to log entries.
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:53,487, getInterestedSubscribers() - Incrementing filtered count for nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:53,487, getInterestedSubscribers() - No interested subscribers. Returning null.
a well processed devices return this log entries:
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, getInterestedSubscribers() - List of interested subscribers -
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, FcssAbstractObjectForwarder - Forwarder queue size is 1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, FcssAbstractObjectForwarder - Forwarder batch size is 50
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, FcssFilterProcessor - Handed off syslog to forwarder. Destined to subscriber nos-ch-wbn-lms1
SyslogCollector - [Thread: FilterThread-0] DEBUG, 10 Oct 2011 22:24:39,445, Entered zero size
here is the output of env
env
TERM=linux
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/opt/system/scripts:/opt/system/bin:/usr/local/sbin:/usr/local/bin:/root/bin:/opt/CSCOpx/bin
PWD=/var/adm/CSCOpx/log
PS1=[\h/\u-ade \W]\$
SHLVL=1
HOME=/root
_=/bin/env
OLDPWD=/var/log
i attached the SyslogCollector.log
regards
alex
Okay, it looks like the problem is hostname resolution.  Check the hostname fx-ch-hom-sw13.frox.com and make sure it resolves to an IP.  If not, either fix DNS or add an entry to the server's hosts file so that the hostname resolves.
Hi Joe,
cool, its working now! Long threat for smal issue.
thanks a lot
alex
