Prime LMS: Syslog filter issue
alex.dersch
Level 4
Level 4
for a subset of my devices i do not receive syslog messages. I believe they get filtered out. I deleted all syslog filters and set the Message Filter Type to Keep and the Include interface of selected devices to Yes. Then I restared the system.
But I still see under Admin > Collection Settings > Syslog that there a messeages are filtered.
Any ideas?
regards
alex
Okay, it looks like the problem is hostname resolution.  Check the hostname fx-ch-hom-sw13.frox.com and make sure it resolves to an IP.  If not, either fix DNS or add an entry to the server's hosts file so that the hostname resolves.
24 Replies 24
Joe Clarke
You should check NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/filters.dat to make sure the filters look right there.  These will be pushed down to the SyslogCollector.
Also, there is a bug in LMS 4.1 if your server's timezone is not one of the common all uppercase timezones.  In that case, syslog messages may not appear when you expect them to.  The bug is CSCts11531.
We use the timezone clock timezone Europe/Zurich. Do you recommend to change the time GMT+1?
This is the content of the filters.dat
Filters for the server: nos-ch-wbn-lms1
Mode: KEEP
Filter expressions:
^((\S+);;;(\S+)(-(\S+))?-(.*)(-(.*\s*))?\s*:\s*.*)$
Yes, you'll need to use GMT+1 or the like to workaround the bug.
The filters do look okay.  All messages should be kept.  Likely they are being written to the DB, just with the wrong timezone offset.
I updated the clock timesetting on the soft appliance. But still i get 135 filtered messages.
nos-ch-wbn-lms11433013501702Sep 25 2011 18:23:45 Greenwich Mean Time(GMT  +00:00:00)Sep 25 2011 19:16:08 Greenwich Mean Time(GMT +00:00:00)
Are you still missing syslogs?
yes, i see them in the syslog_info but not in the syslog report
Enable debugging in NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties by setting log level to DEBUG.  Then restart SyslogCollector and SyslogAnalyzer.  Generate new syslog messages that are not being seen in the reports, then post the SyslogCollector.log.  When you changed the server's timezone, did you reboot?  What is the TZ value in /etc/TIMEZONE?
I attached the syslog.collector file.After changing the timezone i restarted the system.
The /etc/TIMEZONE i didn't find.
What syslog messages are not appearing in the reports?  What version of Solaris is this?  You should definitely have an /etc/TIMEZONE file.
Sorry I forgot to mention, i miss the syslogs for switch fx-ch-hom-sw13 and fx-ch-hom-sw14. I think it is because of this
SyslogCollector - [Thread: FilterThread-0] DEBUG, 26 Sep 2011 05:08:59,051, getInterestedSubscribers() - No interested subscribers. Returning null.
the version is
show version
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.1.043
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: nos-ch-wbn-lms1
Version information of installed applications
Cisco Prime LAN Management Solution
Version  : 4.1
Vendor   : Cisco Systems, Inc.
The parser doesn't support ADE-OS syslogs.  They are being parsed using the generic syslog parser, but the hostname is being set blank (I believe).  I think this will need special attention to get it supported.  This would be worth a TAC SR to get an enhancement bug filed.
Why you assume they are ADE-OS syslogs? The missing syslog messages are from Catalyst 3560 and 2960?
Because you posted a show version from an ADE-OS device.  I had assumed this was other CARS appliances in your network.  The messages were also not in a typical format.  There appears to be an extra component in the message.  Post the config from one of these switches.
The ADE-OS is the Soft Appliance i run the LMS 4.1 on. Here is the config from the switch i removed the interface part.
! Last configuration change at 14:41:44 CEST Sun Sep 25 2011 by cwuser
! NVRAM config last updated at 14:41:50 CEST Sun Sep 25 2011 by cwuser
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname FX-CH-HOM-SW13
boot-start-marker
boot-end-marker
logging buffered 51200
username cwuser privilege 15 password 7 ********
username fxadmin privilege 15 password 7 ********
no aaa new-model
clock timezone cet 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
authentication mac-move permit
ip subnet-zero
archive
  log config
  logging enable
  logging size 1000
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
interface Vlan913
  ip address 172.16.9.38 255.255.255.248
ip default-gateway 172.16.9.33
ip http server
ip http secure-server
logging trap debugging
logging 10.0.128.19
snmp-server group NOSNOCLMS v3 auth read NOSNOC write NOSNOC
snmp-server view NOSNOC iso included
snmp-server location xxxxxxxxxxx
snmp-server contact xxxxxxxxxx
snmp-server system-shutdown
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps config
snmp-server enable traps cpu threshold
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps errdisable
snmp-server host 10.0.128.19 ********
snmp ifmib ifindex persist
line con 0
line vty 0 4
  logging synchronous
  login local
line vty 5 15
  no login
ntp clock-period 22518506
ntp server 172.16.2.241
end
