Prime Performance formula for measuring Throughput
ljuarezm
This is related to PPM formula "Session Throughput" (Downlink and Uplink (Rx or Tx)) for ASR 5k devices, using bulkstats files.
In System there are next formulas:
- System Session Total Throughput Gbp
((8*(sessRxbytes+sessTxbytes))/900/1024/1024/1024)
- System Session Uplink Throughput Gbps
(8*(sessRxbytes))/900/1024/1024/1024
- SystemSessionDownlinkThrougputGbps
(8*(sessTxbytes))/900/1024/1024/1024
900 is the interval between bulkstats counters
Bulkstat reference is "Statistics and Counters Reference, StarOS, Rel18" (for ASR 5k devices)
This reference describes:
- sess-txbytes.- The number of downlink bytes...
- sess-rxbytes.- The number of uplink bytes...
The question is:
According to standards, which divisor is supposed to be used, 1024 or 1000?
(IEC standard, SI or Binary Prefixes)
ljuarezm
Note:
900 is the interval between bulkstats counters, in seconds (15mn)
