04-28-2015 12:14 PM
Dear,
I'm trying do configure the Prime Infrastructure 2.2, in the first access was okay, but now when I try to access by web interface they return with message "username or password invalid", but I didn´t change the password, I can access the Prime using PUTTY SSH with the same user, just not using web interface.
Other probleme, I was trying to importe a template to discovery all switches in my LAN, but all device import by template don´t appear and in the list of device the apper as device missing something with the simble !.
Attach is the template.
04-28-2015 05:23 PM
1.Reboot the server once.
2.try different browser and check if you are seeing the same behavior
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/quickstart/guide/cpi_qsg.html#pgfId-76802
Thanks-
Afroz
04-29-2015 06:32 AM
Hi Afroj,
Today I could log in without problem, I didn´t nothing and is working now. Yesterday I tryed all browser and I couldn't have access.
About the template still the same problem. Do you have any idea what's the problem?
04-29-2015 06:34 AM
could be some transient issue .. hope it should not occure again :)
Thanks-
Afroz
***Ratings Encourages Contributors ****
