Probelm with Campus Manger 5.2
jms112080
Recently upgraded to LMS 3.2 and Campus Manger 5.2. Since the upgrade Data Collection doesn't seem to work. The schedule is in place and I've tried manually forcing it to start with no luck. The user tracking seems to be working normally. Any ideas? Is there a process that needs to be restarted?
20 Replies 20
YANGCCIE4
I read the logs and found there were many error message about STP,
******Unable to fetch STP device instance params from device 10.160.2.44 ****
Is it possible that check this device first, make sure the STP work normal, VTP domain, mode, STP mode, vlan infos and etc.
hope it help
Yang
These errors have nothing to do with the problem being reported here. If anything, they offer proof that the Data Collection is actually running.
Hello
I have exactly the same problem.
After upgrade 3.1 > 3.2 the Data Collection don't works.
No problems with the daily UT Acquisition
I have checked the ani.log and I found a lot of "Validating License..." messages
See the following messages from ANI.log
I have a 1500 LMS License
Time base VMPSMajor has 6 major nodes and 3 minor traversals.
_startTime 2009/10/22 10:00:00
2009/10/22 10:00:00 VMPSMajor ani MESSAGE DBConnection: Created new Database connection [hashCode = 14653147]
2009/10/22 10:01:05 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 14653147]
2009/10/22 10:10:18 NewMACPoller ani MESSAGE DBConnection: Created new Database connection [hashCode = 29439437]
2009/10/22 10:11:35 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 29439437]
I am seeing the same issues you saw here, did you get resolution on this?
start a new thread for your issue.
