Problem adding 2 devices to LMS 3.1 - "Devices Not Configured In ACS"
stephenscott
I added 2 Cisco 3825 Routers to CiscoWorks. We use ACS (TACACS+) for authentication. The devices seemed to be added successfully, but in CM, they are showing as Devices Not Configured In ACS. I checked my ACS servers and the IP addresses are clearly in the TACACS+ group. Does anyone have any idea what is causing this?
5 Replies 5
Joe Clarke
Try restarting ACS and Daemon Manager. Assuming these two devices are in the same ACS NDG as other, working devices, there may just be a communications issue between LMS and ACS that a restart will fix.
I stopped and started the services and now I can not launch RME.
I get the error: License Server/Daemon Manager is down. Please check license.log for more information.
I am attaching pdshow and regdaemon.xml
Thanks.
There are no problems here. This is most likely a timing issue. You should wait at least 30 minutes after restarting Daemon Manager for all of the daemons to initialize and the CPU to settle.
It's been 4 hours...
I rebooted the server and all is well now...strange stuff.
